- Mar 19, 2001
- Bakersfield,CA
I just got my last part for my water cooling setup today so I put everything together. After I got everything together I purged the water for air and started it up and seems to be holding at 46c idle
that is worse thim my fop38!!!
Im using DD maze2 and the DD cube and a good size resivor for the 140gph pump
I have 85cfm of air sucking through the DD cube "120mm radio shack fan"
so Im thinking it is either the GPH that Im lacking or the cfm
I live in a very hot climate "bakersfield" but like I said my fop38 was doing 41c hella loud though
what do you guy recommend I do????
Im a little scared about tieting the maze2 screws any more sense I dont want to crush my 1.2ghz cpu
the spring that came with the maze2 are closed to 3/8" on all sides at the moment "from block to screw"
my case is also open if anyone wanted to know that...
right now my room temp is around 85f
note that the water seems a little hot when I touch the plasic
Im also using around 90% water 10% anifreeze
