- Jun 21, 2001
Ok, Im working on my waterblock ideas. Im looking for the things that make a waterblock better than another.
Im looking for some basic ideas. Dont try to explain the thermal heat transfer of this, or that. Ive tried to read and understand that stuff, and I simply cant follow. Ive done some searching and I havent found what Im trying to see.
Materials I have.
2" x 2" x 3mm silver plate
Plexi galore ~ large, 2" thick, size otherwise can vary
1" x 2" x 2mm? silver plate
2" x 12" x 4mm? copper plate
4' x 2' x 1mm Alluminum sheet
Tools, Dremel and drill, no lathe or any really kewl tools!~!
Im thinking of using the plexi as the main center, the core of sorts. A plexi top. Silver base.
How well will 3mm or 2mm thickness work? Im thinking it might be to thick? but from what Ive heard it is more than likely too thin.
What is a good size for the base (the part that actually comes in contact of the core) to be? the dimensions?
What is a good sized chamber?
I know that turbulence inside is better. I know that if you can get the water to come directly down onto the die area it might be better than in one side out the other.
Ive seen several people use 1 large in and 2 smaller out tubing. How well does this seem to work?
I am wanting to make one myself, thats the reason for this post, which Im sure everyones come to see after reading all this. LoL...
Any ideas?
Thanks.
IFMU
Materials I have.
Any ideas?
Thanks.
IFMU
