- May 23, 2005
I just bought a new water cooling kit with parts I picked myself and I was wondering if I had enough cooling power to cool the parts I have. I will be cooling an OC'd XP-M (2500+ running at 2.5 right now more when water is installed) and a BFG geforce 6800 (unlocked pipelines and shader ). I'll most likely OC that too. Also if anyone else has a 6800 in their loop, has it caused your CPU temps to go up? I heard it warms the loop pretty good.
These are the parts I bought:
Pump: Swiftech MCP655
CPU Block: Swiftech MCW6002-A
GPU Block: Swiftech MCW50
Rad: 2 x Black Ice Pro (using an Antec SLK3700-AMB)
Reservoir
All of this will be running on 1/2in. ID tubing.
My loop will be:
Res->Pump->CPU->Rad->GPU->Rad->Res
I'm really new to watercooling so any input would be great.
Reservoir
My loop will be:
