- Apr 20, 2001
- Sacramento, CA
Well I was having some problems cooling my AXIA 1.33ghz, so I decided to invest in water cooling kit. I purchased an Aquastealth II system from BE Cooling, with the new Jagged Edge Copper Waterblock, and I also got the upgraded Aqua Coil radiator with the 120mm Panaflo. I then headed over to danger Den and bought some elbow connections, clamps, and his MUCH BETTER water block clip. I also bought the Lexan clip from Becooling, but since I wanted to test the setup without ripping my motherboard out, this worked extremely well. Before I had problems running at 1,450mhz, however now I'm at 1.5Ghz (155x10) on an Asus A7M266, stable at 1.84vcore. It's running pretty cool at 43C and I'm happy as can be. The Aquacoil has it's quirks, but everything else worked great. I'm sure I can hit 1.6Ghz. My Crucial PC-2100 (2x256mb ECC) is holding up very well at 155mhz 2-2-2.
I'll have to snap some pictures once I get everything mounted permantenly. Using ebows really cleaned up the hose routing and the waterflow through the system is great.
