- Jun 8, 2002
- Dunstable, uk
Kamerat said:
Take a look at this test.
Ranking (based on "Load Temp (3rd day)"):
1. Shin Etsu G-751
2. CoolerMaster Premium (w/Shin Etsu)
3. Diamond & Artic Silver 3
then you look at this thread:http://forum.oc-forums.com/vb/showthread.php?threadid=134368&goto=newpost
and read colin's comment in particular:
originally posted by Colin
Unfortunately the Inside Project review was done with:
"Hardware monitoring by using a flat thermal probe placed next to the CPU die underneath the shim and HSF"
Any movement of the probe when changing compounds or any contamination by the compounds invalidates the results. Not to mention the severe secondary heat path. It’s sad that so many hardware Sites have such terrible test methodology.
and also freeloaders comments on how he did not experiance anywhere near as much luck as the tester did with "shin-Etsu g571"
Finally, add the fact that i have tested the coolermaster compound and indeed do get 1-2c drop in temps over as3.
are you seriously going to proclaim that the shin-etsu is the best purly based on the fact that 1 single person says it is?
in light of these facts, and my own experiance, i believe that the coolermaster is the best so far
