I don't have a cabinet, but yeah, that sounds great. I suppose I could line the PC case with acoustic foam on both sides (allegedly, roof paper is even better), minus the air holes. And the underside of the top of my desk. And maybe the wall right next to the computer case. Plus one of those anti-vibration carpets like people put under washing machines. I'm already using a double layer of felt.
RE: GPUS, the Zotac Amps at PLN 1500 have sold quickly. There are now MSI GamingX 1080s for 1550.
So basically:
Plain 1070: $250 (Palit, or ~ +$10 for Inno3D)
Nice 1070: $260–270 (40-ish dbA?)
Any 1070ti: $330 (~32dbA)
Strix 1070ti: $350 (~29dbA)
Poor 1080: $250 (40-ish dbA?)
MSI/X 1080: $390 (~31dbA)
The $20–40 increments don't bother me at all, but the huge $80 stop from Palit 1070 to any 1070ti does, considering the performance gain isn't quite +33%.
Then again, considering it can't be excluded that I'd go and buy Accelero and Morpheus eventually, might as well get a Strix or Gaming X right away, on a better chip.
EDIT: Well, then there's Nitro 580 4GB for $150 to just get something better than 1060 3GB, get close to 60/ultra/1080p and forget it for the time being (8GB versions star like $5–10 away but with hot, loud coolers). Still a shame that the card delivers like 45 fps @ 1440p ultra in reviewers' setups, which means more like 40 on mine, so probably not extremely playable @ 1440p. and then I'd like to play around at least with emulated (DSR/VSR) 1440p. And for that it seems a decent 1070 would be optimal (to get 60-ish). On nVidia'a side at the moment no 1060s make sense buying because nice (the ones that really are quiet) 3GB cost through the roof (almost in NIB territory) and 6GBs even more (basically as much as 1070s). Ugh. Decisions, decisions.
EDIT: 'Kay 'kay, reined it in a bit. I've just read some materials about Palit in general and their Dual series in particular, so while I know their 1070 is obviously not going to be best-in-class (which is exactly why it doesn't cost 20% more than it does), it's still by no means a botched product — mostly no frills/bells/whistles. One of the good things about it is that the fans are easy to replace without having to remove the heatsink, and the replacements work. This means the card can easily undergo Noctua Therapy™ for $30 or so. I would basically regard it as a better 1060 to max out my current monitor and forget about the 1060s and 580s as too uncertain. So now this leaves me between the $250 (PLN 1000) for the Palit 1070 vs 1400–1500 for 1070ti/1080.
Can you guys recognize the make of this 1080?
https://allegro.pl/geforce-gtx-1080-mini-i7605272563.html It says 'mini', but the shroud doesn't look Zotac to me, and the rest of the crowd use single fans for minis.
