People use antifreeze for aesthetics. For all practical purposes, using a small fraction of antifreeze in one's loop will not cripple the WC system's performance.uclajd said:Why do you guys use anti-freeze? The thermal properties of glycol only degrade the cooling performance of straight water (glycol has less than half of the thermal conductivity of water).
I use distilled water and a dash of Hy-perlube , just as I do in my car (Hyperlube has anti-corrosion additives, which I doubt any bugs can live in either). I haven't changed my lines in over a year, and it works great. Of course, it isn't cool blue (it's green), so blue dye only gives you a lighter green color (I haven't thoroughly tested blues dyes). But if you want color over performance, so be it.
Antifreeze is for people using chillers who don't want their lines to freeze. Bad for ambient water cooling.
Hy-Perlube has an anti-corrosive, FWIW.Alacritan said:Well, considering my transmission cooler is solid aluminum and my waterblocks are copper, I'll be sticking with my 15% antifreeze/85% water mix. If I could find a copper tranny cooler I'd buy it in a second, but I have yet to find any.
True. I forgot that benefit as well. Whoops.Alacritan said:Well, considering my transmission cooler is solid aluminum and my waterblocks are copper, I'll be sticking with my 15% antifreeze/85% water mix. If I could find a copper tranny cooler I'd buy it in a second, but I have yet to find any.
uclajd said:Hy-Perlube has an anti-corrosive, FWIW.
Liquid_Cooled said:my secret
But I need the deep blue dyelite, not just the regular blue.violineb said:Then I guess you'll be mad when I do this>
http://www.adpmods.com/xcart/customer/product.php?productid=929
http://froogle.google.com/froogle?q=Dye-Lite+blue&hl=en&lr=&tab=wf&scoring=p
Seems to be cheapest in Poland Next time I go over there I'll have to get some.
http://www.4max.pl/default.asp?g=83&gg=61&produkt=633
Jbroad572 said:I am going crazy trying to find this stuff..... Have they just stopped making this stuff?
