He said GeForce3 Ti200 not GeForce4 Ti4200makaka said:my vote is for ti 4200
you cn see in my sig 3dmark 2001 score at stock
Yes the FX5200 is that bad. Its a disgrace to Nvidia Yes it supports DirectX 9 but will have trouble running most DirectX 9 games at a decent or acceptable level of quality. My FX5600 only "JUST" about cuts it for games like Far Cry. I cant run it High everything(but that also goes for most cards) but i can tweak it to an acceptable quality at stock. Overclocking it helps a lot though. I darent even imagine what it runs like on an FX5200...-N- said:lol hm... it looks like it isn't really worth an upgrade then heh. I haven't really been keeping up with current news n stuff cause of school (dumb college), but thanks.
Yea i kinda heard the FX5200 was the saddest card out there or somethin so I was wonderin if mine was actually better LOL. So the 5200 supports dx9 but.. just pitifully?
Looks like I'm just gonna save up for a 9600 probably. good day!
fac_29 said:Yes the FX5200 is that bad. Its a disgrace to Nvidia Yes it supports DirectX 9 but will have trouble running most DirectX 9 games at a decent or acceptable level of quality. My FX5600 only "JUST" about cuts it for games like Far Cry. I cant run it High everything(but that also goes for most cards) but i can tweak it to an acceptable quality at stock. Overclocking it helps a lot though. I darent even imagine what it runs like on an FX5200...
Well if you go for a Radeon 9600 try and get at least a Pro, and stay away from the "SE"... In fact, if you want a great performing card thats cheap get the Ti4200. Dont support DirectX9 but its probably one of the best price to performance ratio cards out there.
fac_29 said:Exactly as Steven said. If its an 128bit FX5200 the FX5200, if its a 64bit memory bus FX5200 then the Ti200. The FX5200 will probably have better image quality though.
Not all FX5200's are the same so its worthwhile finding out exactly which manufacturer, model, Core and Memory Clock Speeds and if its 64 or 128bit memory bus.
The best way you can find out which is best is to benchmark them both in your system and compare. FX5200 is a bit underpowered for DX9 stuff anyway, even though it supports it.
