Sunburn said:Well welll.... looks like AMD is leaking more power than a Prescott. LoL It's official. Now what do you fanbois have to say for yourself?
Socket 939:
http://www.x86-secret.com/pics/cpu/s939/tablew.png
http://www.x86-secret.com/pics/cpu/s939/tablew2.png
http://www.x86-secret.com/pics/cpu/s939/hot.jpg
Hahaa.
First AMD's numbers are not EQUAL to INTELS TDP. Amd's numbers are maximum with even the memorycontrollers power included. Intel's are about 75-80% of max power consumption, they do not calculate the power as P = IV, P = IMax * V.
What AMD include is "1. Thermal Design Power (TDP) is measured under the conditions of TCASE Max, IDD Max, and VDD=VID_VDD,
and include all power dissipated on-die from VDD, VDDIO, VLDT, VTT, and VDDA."
Wheres TCASE Max = Max CPU Temp, VDD = Vcore, IDD Max = Maximum current, VLDT = Hypertransport voltage, VDDIO/VTT = DDR Voltage/DDR VTT Voltage.
Intel clearly states this in there datasheet
"1. Thermal Design Power (TDP) should be used for processor thermal solution design targets. The TDP is not the maximum power that the processor can dissipate.
2. This table shows the maximum TDP for a given frequency range. Individual processors may have a lower
TDP. Therefore, the maximum TC will vary depending on the TDP of the individual processor. Refer to
Figure 12 and Table 27 for the allowed combinations of power and TC."
If you check the maximum numbers they are about 20% higher.
Prescott is still hotter I'm a bit dissapointed at x86-secret over a such simple fault.
Penti
