So to start with, I know my water loop needs redone.
My CPU (5820k on stock OC Genie) idles at 43C. The ambient temp is between 70F and 80F on a normal day this time of year, so 21-26C. I have a raystorm waterblock, xspc 360 radiator with 3 thermaltake RIING12's mounted to it, and a resvior d5 pump combo from xspc. It used to run pretty close to ambient a couple years ago. Since then I have switched to rigid tubing, and my return from the radiator to the res is stupid long because my brother in law thought it would be cool to run it the way we ended up running it. Anyways, I noticed with rising ambient temps it went from idling at 32C to about 40ishC. I noticed build up in the res, so I decided to take apart the system, clean the waterblock, res, and radiator and upgrade to the thermaltake RIING12s. I thought it might net me a few degrees cooler.... but to no avail. The thermal paste I used was arctic silver, but it is a couple years old. Should that matter?
Will a shorter return line have that big of an impact on the temps? When i stress tested even the stock OC (3.8) it hit 60 degrees almost instantly and was still climbing, so i shut it down. I know 60C isnt harmful, but it was climbing fast and I expected it to stay cooler, so it told me what I wanted to know already. 2 years ago I was overclocked to 4.7ghz and it stayed under 60 in 95F ambient temps. I already have more tubing on the way to fix it when I have a slow week during school
