- Apr 29, 2002
It was what the Microsoft Media Creation Tool gave me.
I'm back up with most of my files intact, but my installed apps gone.
How do you look to find out the build?
Beware that may not be 1607 too...
Random MS blog post said:If you have already deployed Windows 10 and use Windows Server Update Services (WSUS) and/or System Center Configuration Manager servicing plans, you can get the Windows 10, version 1607 update on August 16th.
Where is this 1607? It's patch Tuesday, I see nothing in SCCM.
I tried that one first and it erred out just after it finished the download. It wasn't the one that burnt me down.Its being rolled in stages but you can force the update should you choose
https://support.microsoft.com/en-us/help/12387/windows-10-update-history
Z
Explains a lot.The Media Creation Tool has not been updated to include the Anniversary Update, so if you attempt to update your system using media created with this tool, you will simply end up re-installing Windows 10. UPDATE: The Media Creation Tool has been updated to include build 14393.0. Note that this is not the final release build of the Anniversary Update, which is build 14393.1.
9/10 people should - but the ones who won't - tend to hang out on forums like this one, mod their Windows, and use modded drivers.Why not just a fresh install of the latest? Format the drive, install windows. It doesn't get much more fresh than that!
The 1607 iso image has been up since this morning at https://www.microsoft.com/en-au/software-download/windows10ISO
Just have to select "Windows 10" and your language, then it provides 32bit and 64bit links that expire after 24 hours.
For some reason that page isn't served up to me. Just get a blank white page in the latest Firefox, but loads fine in Edge.
