In theory it works. In real, SSD life depends mainly on writes (and luck as it may die randomly), so you can set it to never turn off. If it's a backup drive then you can set it to 10 minutes or something so it will turn off after the backup task. On the other hand, when SSD is in idle mode then TRIM and other self clean/repair technologies are active so turning it off is not the best idea.
