- Apr 29, 2002
I can add the other OSes on other drives later using a BDC editor. I've had windows place the boot loader files on another drive other than the target drive. It didn't ask for permission either.
I think the wisest approach, as you pointed out, is to remind people to physically disconnect all their hard drives. Thanks for reminding me!
The thing that troubles me are multiple partitions, will have to use a dedicated single hard drive just for this and figure out how to avoid that.
I somehow managed to install Windows 7 on a single partition back in the day, with BCD info and OS on the same partition, for easier imaging.
I am hoping to do the same for Windows 10, figure out how to keep it all on the same partition, for easier imaging in case of trouble.
Thank you for that post.
I do not have UEFI BIOS and was therefore happy to see that after disconnecting ALL hard drives and only connecting an empty drive, Windows 10 Beta installed itself onto a single partition. It took up just 13.5 GB - which imaged to 4.72 GB, which is the equivalent of a standard single layer DVD + 365 MB.
When Skylake comes out, I will get back to the UEFI issue, until then I hope you guys figure it out. My hardware upgrades are only when Quantum Leap technology innovations come along: Athlon XP (2002) - first i7 (2008) - Skylake (2015/16)
Windows 10 Beta was the first Windows Beta I ever installed in my life that went through without a hitch. Although when powering down, I do get a DDE Server Window having trouble closing, hopefully it will all be miraculously fixed in the RTM, as Microsoft did with their other Betas - RTM fixes so many problems...
When I got to the Sign in step, I did not Skip it > Signing in immediately identified me as a Microsoft Insider and displayed my join date upon booting into Windows 10 - thereby registering my status one would assume. I was given a key when downloading Windows 10 Beta yet was not asked to enter it when installing, I assume this was because I signed in - which automatically entered my key?
Connecting all the drivers after Windows 10 Beta installed went without any problems and Windows 10 became part of my multi-boot, easily switchable from any of my previously installed operating systems. Installing EasyBCD under Windows 10, also immediately recognized all my other OS, without me even setting up anything.
The wicked Charms is gone completely from Windows 10 and there doesn't appear to be any metro on Windows 10, separate from the Desktop, is that true?
Are you manually installing programs for said OS to their respected Program folders or do you do some registry hack that I've heard about countless times that automatically does it for you like a common PC on just one drive?
I install all small programs to the OS partition and manually install large programs to,
for example, E:\Program Files 8 folder, in case of Windows 8. So: Microsoft Office, WordPerfect, any program taking up half a gig or more, give or take, goes there.
This isn't hard, as using express setup instead of custom setup is PC performance suicide, I never use express setup for anything, so custom setup allows me to manually enter installation location. I have a program intercepting anything that tries to insert itself to start with my PC, and manually allow for that too.
petteyg359, Classic Shell awaits you! It works under 10, and you can setup the Start Menu however you want it to be!
I plan on heavily editing the original menu, hopefully Microsoft will let me do that when I dive into 10, once RTM comes out. I suspect you can get rid of all the square stuff if you choose?
But that is irrelevant as Classic Shell will give you what you want, a CHOICE, since Microsoft did not. But I do like what Microsoft did with the Start Menu, much to my surprise. I did not expect to keep it but if basic customizations are there, I will.
I have only just installed Windows 10 and do not get any problems with mouse clicks. Either way, original or Classic Shell, this will not be a problem for anyone who is allowed to install programs on the PC they are using...
I look forward to customizing Windows 10 to make it easier to use (for me) - other than that, the only thing I *really* need to figure out is how to install Windows Media Center on Windows 10. I can't really do that now since RTM is the only version on which the process will count....
