- Sep 15, 2007
- Small town Emlenton, PA
Lemme see, I would do it if you really had a specific reason because of room. And could take the loss of some heat pulling ability. As long as your temps were acceptable, why not? You'd need stronger fans than what the PA uses, some with high pressure, but ya wouldn't need massive deltas I think.
There are really only two main rules in WC I guess. Don't mix metals and res before pump. Whatever works for you id fine.
I did read up on that at XS when it was tested, it's not a bad concept. Odd, against the best cooling at the expense of room it takes etc, but why not?
