After deciding on the Thermalright AX-7 from all of the reviews, and hearing the stories about the loud noises from the 80CFM Delta fans, I think I have found the best of both worlds.... One of the BEST Heat Sinks and the Quietest of the Delta fans
I will have an Antec-type case with 4 Sunon 80mm case fans.
Abit KR7A-133 MB w/1.4 T-Bird cpu. Will slowly start to OC hopefully up to around 1.5 ......
Will this HSF set-up allow proper cooling under full-load conditions? I was previously going for the Swift-tech, but this seems to be just as good or better, and cheaper....
Thanks for the help...
