Mr_Obvious said:From what I've seen and read, your A7V8xx is the same as my A7V600, as a matter of fact I think it was just a name change. Anyway, if you go to advanced in the bios, and on the very top where it says speed. scroll down thru the choices of whatever it shows your cpu at 100.133.166,200. at the very bottom it says manual. set it there, and it will allow you to manually select all the multi's and all the clock speeds from 100 to over 200. Just be careful, that being a via board, it doesn't have a PCI lock, end you don't want to jack your pci bus up more than 35 or 36. Hope this helps
Changing the multiplier from the BIOS menu works correctly for unlocked CPU's ie like mine, the problem is as stated earlier in the thread after resuming from S3 sleep the multiplier is reset to the default.
Does this happen on your A7V600?
