Max OC thread for E6300/E6400 rev *L2* & pinmodded E4300
Edited to avoid more misguided replies. ^-- Mind the new title.
Hi everyone!
This thread is intended for listing max overclocking results with the following models only:
- E6300 revision L2 (not B2)
- E6400 revision L2 (not B2)
- E4300 pin-modded to 1066 strap
Please use the following format; most info is found on the box/cpu (thanks Evilsizer ):
"Retail" or "OEM"
SSPEC (e.g. SL9TB)
PLANT (e.g. Malay)
BATCH (e.g. Q641A268)
REVISION ("L2" only! If B2, please refrain from posting thanks )
MAX OC on stock volts (Orthos Stable)
MAX OC (Orthos Stable)
MOBO Used / bios, Vcore, Vmch, Vichio/Vsb, Vfsb, Strap
Cooling & Temps (using Core Temp, for now)
Hi everyone!
"Retail" or "OEM"
SSPEC (e.g. SL9TB)
PLANT (e.g. Malay)
