- Mar 12, 2002
DISCLAIMER - I DO NOT BELIEVE EVERYONE SHOULD RUN TEMPERATURES AND VOLTAGES AS I DO, AND TAKE NO RESPONSIBILITY FOR WHAT YOU DO WITH THE INFORMATION BELOW.
So alot of us have these new FX CPUs and the question comes up alot on what the "max safe" temperature and/or voltage to run on one of these chips. The question if these CPUs start crashing above 55C the way Denab liked to has also come up. I have been countering this idea with the the idea that people who are crashing when the CPU hits 55C are simply using too low of a vCore, and that raising it just a tiny little bit even though it raises temps a bit more will restore stability in many situations.
About two months ago I decided to buy a 2nd AMD FX-8320 and have a go at it. I began my testing with the typical OC approach I take and pushed this much weaker sample up to 5.1Ghz on 1.72 vCore, and ran a few 3d benches just to get a quick idea of stability at 4.4, 4.6, and 4.8 Ghz.
Ok so down to the real deal. This CPU has been running Folding @ Home workload running between 4.62Ghz and 4.84Ghz for approximately two months now. In this time I have shut the computer down less than 10 times, and it has not been off for more than 5 minutes at a time. I have not been pausing F@H while doing video encoding, or while playing games. This CPU has been at 100% load since the 2nd day I owned it.
Now this CPU is particularly uncooperative as modules 2 and 3 have a weak core, and module 4 has 2 weak cores one of which will fail unless I set it about 0.04V higher than it takes to satisfy the rest of the cores. To that end I have to use 1.65V to get this chip F@H stable at 4.84Ghz, and 1.62V to F@H at 4.62Ghz.
And here it is my proof that these CPUs are tougher than people think, and careful and PROPER(not reckless) use of high vCore will keep the CPU stable even in the most extreme circumstances. As you can see my system has been running now for 9 days, 21 hours, 40 mins, and 54 seconds at the taking of this screen shot. Also please take note of the 1.62vCore aswell as the MAX core temp reached 81C at some point, and the socket temp hit 85C. All of this and yet my system is still up and folding happily and based on the data transfer I have going ATM its going to be atleast 3-4 more days before this guy gets a reboot.
