You guys have the need and rights to know that RGone used a chilled loop to achieve those clock speeds and voltages and are not relevant to actual ambient cooling.
And because I have to state that because the thread that came from does not, the above voltages are not correct to the clock speed at hand.
It is super very ultra unlikely that RGone and or Mandrake or Caddi Daddi hit 5.4ghz with 8 cores with any kind of stability on ambient temps.
The chart may be accurate up to 5ghz, but not likely past that and certainly not with a "high end air cooler" as another user in this forum has recently stated with A Noctua could only had 4.8ghz and probably on a good day.
I'm sorry. I do not mean to offend, but that chart would be accurate for chilled liquid cooling and I personally do not follow it.
It must be taken with a grain of rice that the figures depicted are strictly tested to his like and set up. results will heavily vary.
And I'd be willing to bet Mandrake would not run 1.7100v with that 6300 at 5400mhz on ambient temps as we speak. (sorry to call this out, but hey.... you know)
Let me edit:
If so... Lets see that 2 hours Prime95 at 5.4ghz at 1.7100v (this I gotta see)
