- Aug 27, 2001
- Dark side of hell
Playcenter2 has stolen my mp3 association and will not let go. I can not find where to disable maintain file assoc. Any help would be appreciated. Playcenter2 came with soundblaster.
Hugo 59 said:I think but am not sure that if you right click on a file while holding the shift key that it will give you the open with option and you can choose what to open the file with and associate it if you want.
Malpine Walis said:You do not need the shift key. Just right click and go to open with...
Hugo 59 said:Wish I could help you more but I don't even know what Playcenter 2 is.
oTTO said:u probably know this: there r some softwares which will check for a default status for the file associations. perhaps there is some option for it not to check if it is the default application for the files...
oTTO said:
if you looked for already its possible there is no option kendan. in fact a lot of bundled softwares is not so good. they use to miss a lot of options, most just like this one (for the advanced users).
kendan said:Playcenter2 has stolen my mp3 association and will not let go. I can not find where to disable maintain file assoc. Any help would be appreciated. Playcenter2 came with soundblaster.
Softwebdev said:
you still have the problem or it's solved ?...........i have the solution, may i tell you?
go into "setting" button will do it
