currently my dd tube seems to have plasticises within like a month or two,
and that has pissed me off
so ive decided to re-tube the whole thing,
issue i have now, all my fittings are 1/2' barb type,
and in my head that seems like a big pain in the ***, if i have to mess with tubing every now and then.
the idea of compression fittings and quick disconnects seem cool to me,
but it seems that when i look at the store pages, i get all mind boggled about exactly which parts i need
i have 1 cpu (2 ports) one gpu (2 ports) one pump (2 ports) one res(2 ports)
and 3x rads (6 ports)
so thats a total of 14 1/2 od fittings, although i think if need be just the pump, res, and blocks would be best with quick disconnects. the 3 rads can be later upgraded if this gets too costly
anyways, can you guys give me a list of the best fittings for this job?
my pump is a mcp 655 (d5 laing) that says the rated pressure is up to 50 psi
i was looking at some fittings that said that was DOUBLE the rating!
id rather like to avoid blowing out my o-ring (gigity)
