As title says...
I ordered some Team Xtreem DDR667 CL3 , which are I'm sure you know D9, so I've seen them pushed up to 525mhz on 2.3V on CAS4.
I have an E6600, so should I absolutely keep an 1:1 ratio for best performance and keep a FSB of around 475mhz , with a multiplier of 8 on the E6600, assuming the processor can take it. If it doesn't, what happens if I let the ram run at, say, 525mhz but the FSB of the CPU is lower?
