dick66482209
Disabled
- Jul 4, 2013
- Thread Starter
- #21
The bottom kit (rated at PC 12800) is the kit I used for both of the screen shots I gave. Now I will admit I was well over the rated voltage, but I was only running 1.75vdimm for 2400@8-11-7-27-1T. For 2600@8-12-8-28-1T, I was using 1.875vdimm.
The kit that's on top (rated at PC 16000) does 2600@8-12-8-28-1T with 1.8vdimm for loose secondary or can run the secondary and tertiary timings much tighter with 1.825vdimm because those are a much better bin. I had the top set at 2800 8-12-8-28-1T on air, but the voltage was 1.9v+ (and only for a short while).
That's what you get when you spend a fair bit on ram. Notice in the serial number of all four sticks pictured, you find "1040." That signifies that the make of the actual ram chip used is X-series PSC. Which is pretty well known to clock to 2400 at 8-11-7 or 7-11-7, and then run 2600 at 8-12-8. I only use those sticks for benchmarking though, as they cost me quite a bit when compared to a run of the mill set of ram. For daily use, I use a set of 1866 9-10-9 crapola.
Give me a vadilator link like this http://valid.canardpc.com/2852987 cause it says what ram your using
You can be just taking a picture of another RAM
