- Aug 19, 2001
- State of Confusion
If you use coolbits to overclock, it has the option to use the overclocked settings at startup. If you do not select that chioce, if you overclock too far you can reboot, and the timings should be back at normal.
once you find the speed you like, then you can select to use it at startup.
good luck!
good luck!
