- Mar 27, 2003
- Dallas, Tx
Im back with some more NEWBIE overclocking questions, and this time I have some new computer parts (1700+ tbred b JIUHB 0307VPMW, and 512mb pc3200).
My main point is that I want to overclock this cpu, as that is what most people get this cpu for. Anyway, I need to know what to do so that I can possibly overclock past 2ghz. What specific steps should I take?
I wish overclocking was as easy as going into the BIOS, changing the FSB to 200, lowering the multiplier, and BAM!!! your cpu is at 2.2ghz. But as we all know, if I were to do that, corruption would happen annd LOTS OF THINGS would go wrong. I know there are several settings in my 8k3a+ BIOS that I need to change, to allow my cpu to be capable of gaining such speeds. What and where are these things?
Should I be worried about the "AGP/PCI 1/5 divider" or whatever it's called, when bumping up my FSB to 200? What is this and is it a big obstacle? And what is this hard drive corruption I hear people talking about? Like if I get my FSB to high, my kt333 chipset may not be able to handle it and will need to lower my HDD "ATA" speed?
I have 512mb of TwinMOS pc3200 ram, but why is it that at the POST screen it says my ram is pc2700?? My maxtor is set at ATA/133 right now, so let me know if I will need to change something. All you 8k3a+ owners out there, What was the highest FSB you guys were able to hit?
Most importantly I need to know what your ram settings are in "DRAM Clock/Drive Control" part of the BIOS. I don't know what to set things at in there. what should "DRAM Clock" and "DRAM Timing" be set to? As well as everything else in there. What are all your settings set to??
I just tried to overclock, and I was really disappointed with the result. I changed the "System Performance" to Turbo, then went to "Frequency/Voltage Control" and upped my FSB to 150, without increasing my vcore at all. I saved and restarted, but my computer didn't even boot. WTF?!?! What steps did you take to overclock?
And lastly, my SK7 with SF II is running at the same temps as my Volcano 7+. Idle temp is 50 degrees Celcius / 120 F, not overclocked at all. (I think that my mobo is reading from the inside of cpu core. Is that the temps are so high?) Are those normal temps?
That's about all I have to ask. Again, I just want some of u guys that have OC'ed a lot to let me in on your secrets. Thanks and hope to hear soon..
UPDATE: I was able to overclockwith the help of scorpio (a friend of mine these forums). Running at 2.1ghz, 10.5x200, 1.625 vcore, 66 degrees Celcius. 11x200 was unstable in 3dmark. ram timings at "Normal." what do u think? what should I do to improve?
