After a huge amount of fiddling - I think I now have two stable OC's to choose from.
I believe I've got a stable 4Ghz and 4.025Ghz -
Manaul "static" voltages used (no offset option currently)
Temperatures range from 75 to 84 - but I believe this is not taking into account the offset.
4000Mhz OC:
vcore: 1.392 under load
NB voltage: ~1.1 or just under
Ram: 3200 1.35v 16-18-18-36
4025Mhz OC:
vcore: 1.416 under load
Realbench stable on both - higher requires 1.43+ vcore (not tested enough)
CPU-Z:
Speeds are lower than set due to bus speed which I can't do anything about currently :/
Is it worth running the slightly slower OC, or just use the best? - I wouldn't normally think about it but I would usually use offset vcore! - Dont think I'm going to bother trying for higher, as vcore goes up quite alot!
Cheers
4000Mhz OC:
4025Mhz OC:
CPU-Z:
Cheers
