- Jan 10, 2012
two on custom loops
one on a ghetto rigged 920 and ghetto rigged zalman resivater
two on custom loops
Going on my third year with my h100. It works pretty good for the most part but it's making a bit of a grumble sound. It's kind if annoying because my computer is pretty quiet these days
At some point, you reach the thermal limit of the heatsink itself. Pushing 1000cfm trough it wont yead anything more than, lets say, 200cfm. Lowering ambiant help but again your stuck at X delta room temp. Waterbloc can take way much more heat cause of the fact that water pass into it right next to the CPU to carry the heat away.
And ill REsay what i told higher on this thread. With all the AIO WC that flow around nowaday, i think this Poll need to seperate them from real WC by adding a category to the poll.
1 : AIR
2 : AIO WC
3 : Costum WC
4 : Other
AIO are not WC IMO. They are wanabee WC and cost 2 to infinite times less money than a real WC. If i was still watercooling with 1500$ oc WC gear like in the past, it would frustrate me to include myself in teh same categori as a 40$ Corsair H50 ....
Does that mean I will be using water cooling? Or is it phase change because of the R433b, even though it gets nowhere near freezing?
R433b operates at much lower pressures than R410a, actually a little less than R22. ( http://i39.tinypic.com/r7sk0j.jpg ) In my design, the highest pressure I have seen was just under 300 PSI when it's set for 140F (dishwashing mode). The compressor was originally designed for R410a, so that amount of pressure is no problem. (Just watch the discharge temperature!) It operates at about 200 PSI normally and the high side cutout is set for 325 PSI. The low side pressure is also lower for a given evaporating temperature, which means that I have the option of running the evaporator fans up high to decrease the delta T (and therefore boost efficiency) without overloading the compressor.Can't find R20 refrigerant? That stuff cools better than the Arctic!
Careful though, R433A runs at very high pressure <410 PSI in some cases..
But you already knew that right?
Now, for benching direct die, it doesn't work quite as well as R410a since its boiling point isn't quite as low. But for long term use, it's much gentler on the compressor and more efficient. Actually getting to the point where the difference matters is problematic for long term use since the compression ratio starts becoming large and discharge temperature shoots up.
just have to wait for the warranty to run out...
Water cooling all the way. It's expensive but I'm glad as hell I started using it.
I just love when you go from 120-125c on load on stock to 35-40c on load overclocked.
Half of your case is over 50c too.
Those were also, with crap tons of well placed fans and going through tons of heatsinks. Best case zalman heatsink I got with my processor was 65c on load on stock and I paid $85 for it. My water kit was $230 + water costs. Spent way more than that in heatsinks trying to find the best one. So yeah, water all the way.
lol.
Welcome to OCFs!
Welcome to the watercooling world. Hope you read enough information so you don't get growth or corrosion.
120c-125c?! That's BAD BAD temps. I would never go past 80c on an intel CPU and 95c-100c depending on the GPU.
Also for $35 you get one of the best air coolers in the market. CM Hyper 2b12 EVO
Thank you for the welcome! I love these forums. I think I have done sufficient research on my part I've been running my build on water for 4 months now and.. it's just awesome. My only complaint is that it gets expensive.
I think it was bad luck on my part that my CPU ran so hot I never had a CPU run that hot on load in my life. Also used to have 80c load GPU temps I got them lowered to 50c with decent air cooling but if I upgrade to 290x sli like I want to in the next couple weeks I'm getting blocks for them.
