- Jan 28, 2004
- Los Angeles, CA
d4m0n said:
My load temps are already 48.5c. Isn't that getting close to too hot?
Also, does anyone know what the safe voltage limit is on a mobile barton? Seems like it should be lower than on a desktop, since the default voltage is lower.
sig updated.itshondo said:d4m0n-
what are your mem timings now?
Thanks. Quick question: what are your idle/load temps like?Zazuk said:d4m0n, VERY NICE OC, that is one sweet cpu. I have been thinking about buying one, but I have a mobile 2400+ at 2500Mhz. I just can't see spending 105.oo for an extra 100 to 200 Mhz. It would be fun to get one and see what I could squeeze out of it.
Gautam said:Give it 2.1v just for the sake of testing. At that voltage, high temps shouldn't be a problem for overclockability, but 24/7 may not be safe.
Good luck to you sir. My 2600+ mobile will do:muddocktor said:Hopefully my 2600m will get here Monday morning so I can see what she'll do. I did get to order it before Newegg jacked the prices up though.
Thanks. I've done no mods to the NF7-S. Just install the CPU and go. The only thing I've done to the board is improved on the stock chipset cooling.Sentential said:Im probably gonna get a mobile soon.
What sorta mods did you guys have to do in order to run it in an NF7 properly?
Oh BTW d4m0n my friend Deepsky has the same RAM He's running 2-2-2-5 @ 410 with 2.8v.
Methinks you and he have BH6. You might want to tighten down the timings and add some x-tra voltage!
Same here. I went all the way to 1.93v and still failed in just over 4 hrs. It gets up to 52c (socket) under load so I don't feel comfortable pushing the core voltage any higher.Red02TA said:Mine just failed at 2600. Gets to about 54C and then fails out. Even with my Koolance I can't keep it low enough. DANG!
I wanted 2600!
These are different than other XP's.. they feel more stable, even though they are not prime stable... other XP's run into a ceiling quickly, where they fail quickly.. Mine isn't doing that.
