Hi guys, i've got my K8N + 2800+ newcastle rig up and running but i've got some big probems.
My temps seems to be really really high, i'm getting 70C load on this setup, accept its not actually failing any stress tests, which you would expect at 70C right?This temps seem to high to be true, i'm using a coolermaster hyper 6 (all the review ive seen of it said it performed better than a sp-97) + 2 fans on the HS + good case cooling. My ambient case temp was never above 25-29C in my old P4 setup, i'm using the same case and fans, accept now its reading 40 under load, wth?
I've heard a lot about getting wrong temp readings on the K8N, i'm using the 1.1 bios you get with the thing, i'd flash a newer one accept, my floppy drive isn't working.
I've heard about something called Winflashing where you flash your bios in windows, if someone could tell me a little more i'd appreciate it a lot. I need to flash my bios to either 1.2, or the beta 1.32 or 1.33 bio's but as my floppy drive is not working depite all the stuff being plugged in good, I can't flash.
Any help would be greatly appreciated.
Thanks, Mark
Thanks, Mark
