- Mar 30, 2004
- Northwest Indiana
First off here are my system specs:
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.20GHz
Speed : 3.52GHz
Performance Rating : PR4682 (estimated)
SMT Support : 2 Unit(s)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Mainboard
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support : 1 CPU(s)
MP APIC : Yes
System BIOS : American Megatrends Inc. 1016.001
System : To Be Filled By O.E.M. To Be Filled By O.E.M.
Mainboard : ASUSTeK Computer Inc. P4C800-E
Total Memory : 1023MB DDR-SDRAM
Chipset 1
Model : ASUSTeK Computer Inc 82875P,E7210 Memory Controller Hub
Front Side Bus Speed : 4x 220MHz (880MHz data rate)
Total Memory : 1024MB DDR-SDRAM
Memory Bus Speed : 2x 220MHz (440MHz data rate)
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86/IA32) 5.01.2600 (Service Pack 1)
I currently have the 3.2ghz P4 overclocked 320 mhz and it runs 100% perfectly stable all the time. I have 4 256MB sticks of Kingston HyperX memory and its PC 4000 configed in bios by SPD. The heatsink I got is a Coolermaster Hyper 6 HSF with arctic silver 5 with plenty of case cooling and under full load the system never goes over around 34c and sits idle at about 21-24c with a pretty cool ambiant room temp.
Ok now heres my prob. I want to be able to overclock my system to 3.6ghz (Actually 3.7), but when I get to 3.6 the problems start. I'll up the FSB and it will run and boot at 3.6ghz. I run sisoft burn in and it will be fine with temps just slightly higher than they are now. Then I'll get out to play a game or maybe just open a app or click on something on my desktop and then blue screen. I'll reboot and then maybe it won't boot and I'll get a bluescreen. Then i'll reboot and it will be fine. Open internet explorer - Bluescreen, reboot, it will be fine, run burn in again...passes without a problem. AN on and on. When I get the blue screen is says something about win32.sys or sometimes IRQ_NOT_EQUAL_.....blah blah blah. I tries everything I know in the bios to maybe stop this. I should be able to hit 3.6 no problem with the cooling I have. I have the vcore on the cpu at 1.6 and I also have tried a slew of things, Like:
Disabling PAT
Turning memory voltage to 2.85 (or is it 1.85 I can't remeber)
Turning off memory turbo mode
Dropping mem from 400mhz to 320mhz
I don't know what could be causing me not to be able to overclock my 3.2 to 3.6? I should be able to go higher I think. Is it my memory, is it a bios setting I might be overlooking? This is really upsetting me because I know i should be able to get a better overclock. Anyway if anyone could help with advice on what to do to make me be able to overclock more I would appreciate. Thanks!
Processor
Speed : 3.52GHz
Type : Standard
Mainboard
MP APIC : Yes
Chipset 1
Operating System(s)
Disabling PAT
