I just purchased a Gigabyte GA-X99-Gaming 5P motherboard, and I'll be recycling my old PSU (Kingwin Lazer LZ-1000 1000W 80 PLUS Bronze). I was reading through the manual, and I came across this little blurb...
When you overclock the CPU, make sure to connect one end of the included 1 to 3 power cable to the ATX_12V_2X4 power connector and the other three to the power supply to ensure the system is provided with enough power.
To my knowledge, my PSU only has 2 8pin power connectors. So I guess I have two questions. Is connecting 2 power connections to the 3 to 1 adapter better than just the single 8pin connection? Should I try to do some crazy configuration with adapters to ensure all it's using all 3? Would overclocking be out of the question if I only use 1 8pin connection? It's weird that this is kind of sneaked into a footnote of the manual.
