- Aug 14, 2014
AMD Ryzen 5 5600X3D Rumor Foretells of a Budget AM4 Gaming Champ
New AM4 chip may boast the same 96MB of 3D V-Cache as its bigger brother.
www.tomshardware.com
Don't think so, haven't seen it in any review?Have any sites done a "simulated 5600X3D" test yet, by disabling a couple cores from a 5800X3D?
There is a big difference in some games even with the 2*** generation, don't forget that it not only improves the max FPS, but (to me at least) the best thing is the 1% and 0.1% uplift which makes the games silky smooth "Problem" would be that is mainly only CPU bound games, older games that only use 1-2 cores and online games, especially MMORPGs which are draw call monsters, so greatly benefit from the extra cache. Most GPU bound games don't see almost any difference, so it's really up to you and what you playIf I was on a tight enough budget to go 6c/12t I would just get the 5600. Even at 1080p, how much do you have to spend on a GPU to notice the difference between the x3d and not. I understand the principle of test rigs using the best hardware to show the most difference between the components tested, but if the part that is 50% or 100% more expensive will show no difference in a realistic setting, then that should be shown too.
Didn't they take it down with the crypto crash?Huh... we dont have an eggplant emoji?
That's his point. X570 didn't have native support. It looks like you need F30 for X3D chips.No update needed, just plug and play if you are running a bios that already has X3D support.
I forgot that 5600X3D came out at the beginning of this month, WELL after the other 5000X3D chips. I would also worry about it not being supported fully without a BIOS update, but I can believe it would be (just wouldn't bet my life on it, lol).I was asking if a 5800X3D bios would also support the 5600X3D, or whether an additional update was required.
