- Nov 29, 2002
- USA
Isn't Chiphell the same site that posted the bogus photochopped pics? (at work and can't see those in the thread because they are blocked)
Probably just spotty prerelease drivers or something.
What drives me batty is the graphs themselves. They made the Nvidia baseline show as 100% on the graph but then 120% performance is a bar fully twice as high. It makes it hard to tell at a glance. Lies, damned lies, and statistics, I guess..
very hot indeed.... nothing watercooling cant fix though
He's got the fan manually set to 20/30%. Temps are pretty low, considering that.
$400?!?!?!??!!?!!!?!
I thought they said it was suppose to be cheaper than a GTX285. Maybe I'll wait for big green to drive down the price.
If you consider how much smaller the die size is than nVidias 200 series, it would be much harder to cool. Cant fit 4 heatpipes on a tiny die.
is it just me or does the 5850 just stomp the 4890 in sheer power? also, the 4870 was $300 when it came out, why can't these follow suit!?
nVidia will do a paper launch of the whopping SEVEN examples of the GT300 cards they made with their first wafer
