AIOs might be the way to go . Why do I say this , Is for the noise level if not looking for max OC performance 100% of the time. You can put some decent Fans that run @ a low rpm but still have good static pressure and it will have a much lower sound level than what you could get off air .
Once you go water most never really want to go back .
You can reuse water kits for years if you want even if you have to bust out some DIY brackets to make some things work .
When water cooling you dont really need to go for the TOP gear . Lower quality / Older blocks still do a great deal on systems .
I had a old RDX cpu block on my 950gtx . 30-40 deg temps on gfx cards is nice to see I love water on cards even when it doesnt help the oc that much .
If something DOES go wrong, it'll be much harder to detect, and downtime will be much longer.
AIO's are not more quiet than a proper air cooler, nor do they give meaningful performance gains. I can link about 300 tests/shootouts that show this. AIO's benefit from size alone; you can fit a radiator in a smaller case to maintain performance.
Plz link where a 3x120 aio gets beaten by a air cooler when normalized to 40dba
Hi guys,
I hope you had lovely Xmas. Thank you for all your answers, you are really the best.
I want to ask you also about buying card with water cooling GPU.
How often do you have to change liquid and is it very hard to do it?
Do you have some reliable benchmarks of them?
Is it even worth it, or is it better to buy a card without water cooling?
If so - which one from GTX 1080 Ti do you recommend?
I understand, that you are not recommending water cooling for my purpose. It applies to GPU as well? I mean - place where GPU is mounted looks safer in case of leaking, or am I wrong and it's not worth it anyway?
Have a nice day!
Can't say as I saw anything that makes me want to run out and get a Noctua DH-15 over my 360 AIO.
Ok. How many would you like to see?
http://www.relaxedtech.com/reviews/noctua/nh-d15-versus-closed-loop-liquid-coolers/2
Performance gains are in the "near negligible" range.
Well you already own the AIO. Considering the NH-D15 gives nearly identical performance for half the cost... ehh its your money. Ultimately, thats fine; AIO's have their place. Looking at it from a business perspective, AIO's shouldn't be entertained, unless it serves some specific function.
"Already own" is a biggie. And it looks good in my case with the red fans. It also isn't as limited by case airflow as an air cooler would be. I can flip my fans and use them to pull outside air in if needed, without ramping up noisy case fans or or being as concerned with placement of my rig. There are definite advantages (for me) to a 360 AIO.
I'm surprised that the Noctua NH-D15 costs as much as my H115i did.
