- Oct 11, 2002
- The Empire State
Well, finally got the cojones to go ahead and do the vmods on the Enermax psu in the dualie. Lemme start by saying this is the same mod i did that killed the same exact psu i had in my P4 rig. My guess was there was more than 1 guide and several different ways to do it. I went with the first guide which is supposed to be the original. Apparently it killed the psu The patient that was operated on was the Enermax EG465P-VE .
So what's different this time? Well i used a different approach along with countless days of research. This is the guide i used this time and tho it was scary as hell, it was a success The fear was i thought i was gonna have a repeat of "Die psu pt1", but to my surprise it went very well. I also went ahead and did the +3.3v mod. I figured what the heck right?
B4 the mods:
MBM shows:
+3.3v = 3.34v
+5v = 4.84v
+12v = 11.98
DMM shows:
+3.3v = 3.39v
+5v = 5.04v
+12v = 12.13v
Now after the mods:
MBM shows:
+3.3v = 3.42v
+5v = 5.15v
+12v = 12.55v
DMM shows:
+3.3v = 3.50v
+5v= 5.40v
+12v = 12.72v
Mind you by adding the 10k pot in series with the R82 resistor it raised the 5v line dramically, but the bonus is it also raised the 12v line too So you get 2 mods in 1 which i think is awsome. The downside is it's a tricky mod and you have to pay close attention to what you're doing otherwise it will result in a dead psu with the quickness. Because the psu is in my dualie (MSI K7D M-L) if you crank the +3.3v rail pass 3.5 volts, the mobo will refuse to boot with that siren and the LED displaying the memory error. I just tuned it down to 3.5 and she's rock steady stable. Hope this helps someone out there with the same psu.
B4 the mods:
MBM shows:
+3.3v = 3.34v
+5v = 4.84v
+12v = 11.98
DMM shows:
+3.3v = 3.39v
+5v = 5.04v
+12v = 12.13v
Now after the mods:
MBM shows:
+3.3v = 3.42v
+5v = 5.15v
+12v = 12.55v
DMM shows:
+3.3v = 3.50v
+5v= 5.40v
+12v = 12.72v
