Ok, I just got overclocked my q6600 to 3.15 ghz and I'm running a stability test right now. I was watching the temps in speed fan and here they are:
Temp1: 47C
Temp2: 51C
Temp3: 44C
HD-: 45C
TEmp1:39C
Core0: 59C
Core 1: 58C
Core2: 55C
Core3: 61C
This was after about 10 minutes in the stability test. My fans nearing it's max RPM of 2500 (currently 2300) is this too hot you think? And if it is is there some way I could force my fan to give me the extra 200 RPM? And I guess overclocking to 3.6 isn't going to happen? Also would putting some more thermal paste on it decrease the temps a bit? And how long should I run the stability test for? 3 or 4 hours long enough?
Temp1: 47C
Temp2: 51C
Temp3: 44C
HD-: 45C
TEmp1:39C
Core0: 59C
Core 1: 58C
Core2: 55C
Core3: 61C
