That should be a SLACR G0 Q6600. May I ask the voltage as read in CPUZ (Core Voltage)?Family: 6 Model: F Stepping: B
EXT Family: 6 Ext. Model: F Revision: G0
Try 1.25 vcore.
i dont think that is, but maybe it is. try looking for something called cpu voltage, or vcore or something like that.
Those temps are actually pretty good. Just stay 25 - 30c away from tjmax and you'll be fine. DON'T put more thermal paste on though, whatever you do. Any more would most likely raise the temps by insulating the CPU. If you can't get to 3.6Ghz, it's most likely you're NB running too hot, or your RAM running to fast. For example, I can't get above 3.82Ghz at the moment because my NB runs too hot when I start raising my vCore above 1.3v (I'll have to get a separate fan and strap it to the NB). Run the initial stability test for at least 8 hours (over night is easiest). Most people say 24 hours, but that's too long for me because I need my frickin PC!!
Intel's max temperature for the SLACR G0 Q6600 is 71c and 62c for the SL9UM B3 Q6600.
