- Jul 7, 2013
- Thread Starter
- #21
Disable the Q-Fan Control and see if the fan is recognized.
If not, switch the CPU_FAN and CPU_OPT and see what happens.
If you cut the Q-Fan off for the CPU fans, can you control them from Windows?
SpeedFan should work.
The only issue I see arising is not getting the computer to POST because of a "missing CPU fan"
get a part number off your fan and do a web search and see if it has a tach signal.
if it has no tach signal, run it on a cha header, iy will adjust the voltage in relation to the socket temp even if it has no tach signal.
f you go with a larger AiO units you will need to or should put a fan blowing at the socket of cpu and the VRMs in order to drop the CPU/Socket temps.
RGone...
