Bill Dimwit
Disabled
- Mar 21, 2018
Just wondering, are there any 70mm radiators out there? I seen 40mm,50mm,60mm and 80mm but never 70mm.
Just so we are all on the same page here.
I mean a rad for 70mm fans, not 70mm thick.
That bad?
I know 70mm fans aren't all to comon out side of blade servers anymore, but given their once popularity along with 40,50,60mm rads being out there youd think 70mm rads would be available.
Maybe ill do more modding to my case and fit a trible 80mm rad in the back of the case.
What case are you working with and what other Rads are you using?
I think your best case scenario is to create a external system with just the tubing going back inside the case to the blocks and back out.
Also, as you probably already know, you will only get the temps your ambient range will allow so if you're in a already warm environment, any cooling won't do much if it's already high.
Honesltly, if you want silence, stick with 30mm-45mm rads from alphacool with some nice low to mid speed quality rad fans. You don't want to go too think otherwise even with a low fpi rad, you still need to jack up the fans a bit unless you're doing P/P say around 1000 RPM but I personally wouldn't go lower then 1200-1400 RPM on a 80mm thick rad.
I appreciate the help guys, but your preaching to the choir.
On topic. One thing that's over looked with thinker rads is the increase in surface area and water volume. If done right a the loss of air flow through the rad will be somewhat canceled out by the larger surface area and water volume. However in the long run without a push pull setup or 38mm or thicker fans and a stronger pump or a rad with really low FPI things will get hotter then with a thinner rad with similar FPI.
But a thinner rad can also lead to hotter temps in the long run too. Your run into the problem of not having enough surface area to dissipate the heat with out faster fans. There is a happy medium in regards to cooling, rad size and fan RPMs.
I think you're giving too much credit to thicker rads versus the thinner rads. Sure the more heat surface the better but usually that plays out better if you were to add more rads in general then just base it on thickness of a rad. You won't see a huge difference between a thick vs thin but the thickness is there if you're aiming for every little decimal of a degree but hey, to each their own.
