Well this sucks. After doing some detailed measurements I found that fitting a 80mm rad in the back will not work so well.
The CPU card sticks out to far and Id have to make a new flat rear pillar that is also includes the rear panel.
Right now the rear panel and pillar are two pieces of metal screwed together and they would have to be one piece to fit a 80mm rad. Being one piece would widen the usable mounting space by about 8mm.
Wile I could make it work, it be a tight fit and even less ideal.
I have the room for a triple 80mm rad in the case, but not without modding the rear pillar and panel and getting a thinner CPU card.
Oh well.
I'll lap the GPU heat sink and put better TIM on it. I already (poorly/quickly) lapped the CPU heat sink and it drooped about 15c
that's the biggest jump I ever seen from just lapping a heat sink. The surface of the CPU heat sink did look like it was belt sanded to 250grit. I lapped it to 2500 grit stating a 200 grit to flatten it out.
Once I get a 7700 I'll lap it better and put a fan on it.
I ordered better 70mm fans for the rear. They will push a little more per dba and I'll put a third 120mm fan in the front of the case.
Hopefully all that will shut the system up.
