I set my voltage below 1.3V and run Extreme LLC so it gets to right around 1.3V full load, which is stock voltage. Ya, my OC is mild right now, but I'm working my way back up to 4.3GHz, hopefully.
You could be right about that RGone, that may be necessary for Gigas.
@ Tyerker, Looks like with Will's Rev1.1 it acts a bit different since his volts go up from his setting under load. Maybe your older rev needs that setting to compensate for the droop.
