That's the next things I was going to ask you fine gentleman about. I wanted to go with the 8350 for more of future proof-ISH CPU. Not expecting it to not get out performed at any time soon but I figured may as well take the 8 core if I have the money. But then I think about just OCing the 6300 and saving 60 bucks or so. Do you think the 6300 will be just as good as the 8350 for gaming in general? I've heard the 6300 is a nifty little CPU
The 6300 is a great cpu.How many games need 6 or 8 cores to run smoothly ? None! Plus,the advantage of using a cpu thats 95W vs 125 Watts.Gaming is no problem on Utra or high textures.I game @ 1080P with (1) 24" monitor,and (1) video card.For a more elaborate set-up, I dont know....
I have (3) Gigabyte GA- 970A-UD3 boards,and have no problem overclocking my 6300 to 4.5G.I backed it down to 4.4g where temps are more to my liking.It can handle cpu's up to 140Watts.The 8350 is 125 Watts,so no problem.These are budget boards @ about 110 dollars,so no comparison to boards listed.I never had problems oc-ing on the 970,and run one of my pc's 24/7 365, for 2 years with no issues.During this time I was using a Phenom II 965 oc @ 3.8g.These boards are built like a tank.Solid! I hate flimsy boards.Gigabyte makes it very easy to update bios using Q-flash.I flashed 2 of my boards to F7 to make board compatible with the new FX cpu's.
These are great boards,but not cheap.One advantage,of many, is you'll have the option to add another video card using a 16X PCIe slot,where lower end boards only give you the option of (1) 16x PCIe slot.Some advice I was given that helped in my decision.Choose the board which has enough SATA, USB, PCIE, LAN or other things that you need.
Asus Crosshair V Formula/Z
Asus Sabertooth 990fx R 2.0
Asrock Fatil1ty 990fx
If you decide to go with a Hyper 212,just make sure your ram is low profile,so you wont run into clearance issues.I use Corsair Vengeance ram,and never had problems.Brand is debatable,but low profile for a 212 is a must.If I was using a 8350,I would cool it with this
http://www.amazon.com/Noctua-Heatpipe-Bearing-Cooler-NH-D14/dp/B002VKVZ1A/ref=cm_cr_pr_product_top I hate the colors,but it comes with 2 quality fans,so the price is justified. The next step up from this HS would be water cooling.
