OP P Piercex181 Registered Joined Dec 26, 2015 Dec 26, 2015 Thread Starter #21 Yes, HPC is enabled and APM, CE1, CnQ and C6 are disabled.
Johan45 Benching Team Leader Super Moderator Joined Dec 19, 2012 Dec 26, 2015 #22 I know this sounds off but did you try with APM enabled as well. Giga boards seem a bit different
OP P Piercex181 Registered Joined Dec 26, 2015 Dec 26, 2015 Thread Starter #23 I'm pretty sure I have at some point, but can't remember exactly so I can try that.
Johan45 Benching Team Leader Super Moderator Joined Dec 19, 2012 Dec 26, 2015 #24 HPC and APM enabled with the rest disabled
OP P Piercex181 Registered Joined Dec 26, 2015 Dec 26, 2015 Thread Starter #25 After a few minutes it starts doing the same thing as my previous screenshot.
OP P Piercex181 Registered Joined Dec 26, 2015 Dec 26, 2015 Thread Starter #26 Flashed to FDc, same thing.
OP P Piercex181 Registered Joined Dec 26, 2015 Dec 26, 2015 Thread Starter #27 Well, thanks for all the suggestions everyone. Think I'm just going to let it be for now until I can upgrade. Thanks again.
Johan45 Benching Team Leader Super Moderator Joined Dec 19, 2012 Dec 26, 2015 #28 One thing you could try is AMD MSRtweaker, I know it can disable APM as well there are many guides for it. Pretty sure you need to be in Win7 though http://www.xtremesystems.org/forums/showthread.php?285742-AmdMsrTweaker-New-Versions
