Starwarscards
- Mar 6, 2018
Need overclocking help but specs and changes first.
specs:
Intel Core i7-8700K
Corsair Hydro Series H115i
ASUS ROG Strix Z370-E
CORSAIR Vengeance LPX DDR4 3000 16*4=64
Here are the things I changed:
Asus Multicore Enhancement: Disabled
SVID Behavior: Best-Case Scenario
AVX Instruction Core Ratio Negative: 1
CPU Core Ratio (Sync All Cores): 50
CPU SVID Support: Disabled
BCLK Aware Adaptive Voltage: Disabled
CPU Core/Cache Voltage: 1.310
CPU LLC: 6
VRM Spread Spectrum: Disabled
Intel SpeedStep: Disabled
CPU C-states: Disabled
Intel Speed Shif Technology: Disabled
Ok so was trying to get it to 5.0 so worked my way up doing Intelburntest "very hard" x10. Could not get it to 5.1 so went back to 5.0 and pulled up Prime95 Blend test to check for a few hours before I did the Cache and Memory. Within a few minutes I get a Worker stopped and a rounding error. Increasing Vcore does not help. Temps for Intelburntest max at 86 according to HWMonitor.
So anyone know what is going on and what I can play with to fix it? Also since I am already here anything I should not have disabled or should disabled?
Thanks in advance for the help
specs:
Intel Core i7-8700K
CPU LLC: 6
