- Jan 10, 2001
The problems you guys are having was a known issue with the 8rda series boards from the begining.The heat from the mosfets is just to much for the nearby capacitors.I was aware of this from the AOA forums before I purchased my 8rda+ 1.1 revision mobo.I don't think the capacitors are the same batches as the ones that were going bad on all the other mobo's as they were produced later.There are just to many mosfets in close proximity to the capacitors which also happens to be in a place that doesn't get much air circulation even with air cooling.
Even before I installed my board I modded the mosfets with cut up heatsinks so that the 5 volt line would not suffer from the extreme heat.Even with the mod the haetsinks can be very hot and even burn your fingers without some active cooling.I also went with an 80 mm fan on my 60 mm sk7 so the overhang would cool the other heat sinks and PCB as well.Of coarse I voided my warranty before I even installed it but I knew the risks and benifits when the N-Force chipset was so new.I will attach a pic so you can see the the mods.I have an early revison non crush chipset so 200 mhz was a little more than I was expecting.
