- Nov 17, 2001
- Corpus Christi, TX
I was looking into getting the Asus NCCH-DL board but read that it required a 24 pin power connector. I've got an Antec 400W PSU from about 2001 and is plugged into a Epox 8KHA+ which uses the 20 pin connector. Now Antec's site claims that mobo's "requiring" the 24 pin connector will actually work with a 20 pin connector, mentioning the extra pins are for powering a PCIE card.
So question 1 is, will my current PSU work or do I need to upgrade?
Next up, Newegg has Intel Xeons with the following pins "604 pin FC-mPGA", "Socket 604", and "604 Pin (FC-BGA)". Some retail, some OEM. Which of these will work with a NCCH, or are they all really the same?
Thirdly, I saw that OC'ing a 2.4GHz Xeon to ~3.0GHz is the way to go, but will a 2.66 GHz get me farther, it's only a little more expensive which is why I ask.
Finally, should I get 533 FSB or 800 FSB? 800 seems the obvious choice but a lot of people are talking about 533. Does 533 OC better?
I can provide links to the places I'm getting my info from if it would help.
Thanks in advance!
Thanks in advance!
