- Oct 10, 2008
- Jersey
Ive been working at getting my comp stable for a while now. Thanks to a number of ppl in these forums and a ton of patience on my part, im getting close to my goal.
Heres whats going on.
For now im just trying to get my q9550 stable at 3.2 ghz. Id be happy with that but perhaps when things start getting closer to perfect, ill consider going higher.
Im using a evga 790i ultra sli mobo and 4 gigs of ocz reaper ddr3 1333mhz pc3 10666. The problem i think im having now, is finding the right voltages.
Ive got the sb and nb volts running pretty good i think. But im not sure what voltage the cpu should be running at 3.2ghz. Ive tried a number of voltages between 1.2 and 1.3v. I havent gone higher then 1.3. Now i know that some ppl aiming for 4ghz will run the cpu at 1.4v but i dont think im that brave lol(or have enough money if i mess up and fry something) Ive used prime and OCCT. even though my comp seems more sluggish then it should be occt says all is well after its 2 hour run. I havent wanted to chance running prime all night just in case it starts running too hot, so i havent ran prime for long. Usually ill set things up and run occt for 2 hrs, watch a movie and occasionally check up on the temps with hwmonitor.
If someone is familair with this cpu in this board, please lemme know about what range of voltage i should be running the cpu at to get it perfect at 3.2-3.3 ghz.
Ive got the multiplier maxed at 8.5 ,because i havent really had any lockups up at all, just the occasional inability to make it past post screen, then i go into bios and adjust it a bit and starts up fine. No BSOD or anything during my time trying to oc it.
Im using the newest p07 bios for the board btw.
im really close to gettin this sukka running good, so please anyone with experience with the q9550 and/or the 790i ultra, please let me know what your opinions are. Thanks guys, you've all be very helpful.
