- Dec 3, 2002
- Mountains of N. AZ.
Right, first, the specs:
Abit nf7 rev 2.0, bios 18 - Northbridge voltage 1.7
xp 2100+ @ 2365 (215 x 11) - vcore 1.65
Powercolor 9700 non-pro flashed to 9700 pro @ 340/274 (3.6ns mem); AGP voltage @ 1.5 ; connected to Viewsonic 21" P810 monitor, using digital out to 5-BNC connector cable; also regular DIN video cable.
512mb (2x256) Samsung pc2700 DTM @ 215fsb, 3-4-4-8; 2.8 vdimm.
Enermax 350 watt power supply w/ 90mm intake fan, 80mm exhaust fan
2x80mm exhaust, 1x120mm side intake, 1x120mm front intake.
Now, the problem:
When cold booting in the morning (for the past 3 mornings), the PC starts, boots up, and when display comes up the video is totally garbled. I mean - random color blocks, not readable at all. Just garbage. This is with both video cables - either the BNC (which connects to DVI-A out) or the DIN.
The only way to fix it is to power off, turn off the powersupply, let all power drain, turn powersupply back on, turn on PC holding down Insert key. This will pull up POST screen w/ message "cpu unworkable or has been changed", at which point I go into BIOS, make sure everything is set ok (does not change from before), reboot, and video is clear & normal.
Today, however, this was not the case. Went through the steps of shutting it off entirely, turning back on, starting it up holding INS key - still garbled. Sometimes it takes a few tries (invariably after turning off and then back on, gives no POST beep, have to do it a couple times), but no luck today.
When I can get it going, it runs just fine - no artifacts while playing, etc. Can warm reboot no problems as well - seems to just have problems with cold boot.
So, my questions:
1) do you think my powersupply is inadequate, therefore not giving enough voltage for the signal to be clear?
2) do you think the AGP voltage should be upped a notch?
I'm of the opinion that it has to be one of these problems. I did not experience this problem w/ my old board: a KD7-E. Vid card performed flawlessly on that board. So, it rules out a cold boot voltage problem, unless the nf7 voltage requirements are different - considering the onboard LAN, sound, etc, it would seem to need more voltage than the KD7-E, logically.
Anyone have any theories on the cause of the video being scrambled/garbled on cold boot?
Now, the problem:
So, my questions:
