Yep, I guess they did have both a 125W and a 140W version now that I do more research. The model number on the top of the CPU would tell which one.
YES IT SAYS 125W
now can we get back on topic to find out why its so hotÉ
lol
^^^ Correct. Keep in mind that it doesn't matter how good your heatsink is if the ambient temperature inside the case is already hot. Airflow within the case s paramount. Once you have that right, then get a heatsink.
It's because you have inadequate cooling. You only have 1 fan in the front and 1 fan in the back, plus you're on a default heatsink. Being on a default heatsink alone is gong to limit your overclock because they are not made for super powered machines...they are made for very slight OCs.
my case can add 5 more 120mm fans lol
so now i should buy a few fans?(like 1 or 2 more)
How much thermal paste did you apply do your chip/HSF? Was it already applied before attaching it to the chip? If you applied your own what kind are you using and what method did you take on applying the paste?
Well, pressure per se may not be important but through put (cool air going in the case and warm air being forced out), however you do it, is critical in my opinion. Cool air blowing onto a hot component may help that component but unless there is pressure relief in the case the heat coming off that component is just being moved aside and building up in the case.Yes, yateloons are inexpensive and work decently for the price.
Try and keep intake/exhaust as balanced as possible. (2 in 2 out)
However pressure has nothing on direct air cooling. You get cool outside air directly to the hot spot f your PC... thats going to be more important than maintainin balance or using a positive or negative designed cooling system.
