Whatever.
Do you have another source that says otherwise?
Okay, then its a 125 TDP board. That's why it works with that CPU. Now you just need a better cooler. Go for the Coolermaster Hyper 212+ evo. Get some extra case fans, too.
Here, this should fit and give you the cooling power you would need to take that CPU to an overclock that the motherboard will also handle.
But what's the core temp under full load? Idle sounds good but doesn't tell much unless it's already unusually high.
That's certainly acceptable. Is that at stock voltages and frequencies or overclocked?
Got your case fans yet?
